Author Topic: 71 motor swap  (Read 8916 times)
Offline fatheadinc
  • Pinto Member
  • FeedBack: +2/-0
  • Gender: Male
71 motor swap
« on: June 07, 2003, 02:02:13 AM »
will a 74 2.0  bolt up to a 71 1.6 man. trans with no problems sense a 71 also came with 2.0l too....
pinto brain child
74 runabout butcherd bbf project
victimized 71 sedan
Offline turbopinto72
  • Master Mechanic
  • Administrator
  • Pinto Sr. Master
  • FeedBack: +170/-1
  • Gender: Male
  • Your never to old to go fast.
    • Brads Pintos and Pangras
Re:71 motor swap
« Reply #1 on: June 07, 2003, 10:16:46 AM »
Another Great question. I can only "assume", that being as I have only seen one type of 2.0 bell housing, that there would not have been a " special" bellhousing and trans just for the 1.6, however the 1.6 and 2.0 motors are verry different. I have seen a different Automatic bellhousing with the starter on the Drivers side ( dont know what that was for but maybe a right hand drive car). I will look into this a little further and get back to you.
Offline fatheadinc
  • Pinto Member
  • FeedBack: +2/-0
  • Gender: Male
Re:71 motor swap
« Reply #2 on: June 09, 2003, 10:26:47 AM »
i appreciate any info on what to look forward to on switchin this thing out i noticed wright off the bat the intake and  exhaust are on the opp. side from the 2.0 i sure hope the trans bolts up to it i dont want to go and buy another one
pinto brain child
victimized 71 sedan
Offline kd5fnb
  • Pinto Member
  • FeedBack: +0/-0
  • Another Pinto Driver
Re: 71 motor swap
« Reply #3 on: September 07, 2004, 07:18:20 PM »
i am looking for a 1600 motor.or a crank and rods.if you have a set email me with price. thank you
                                                        kd5fnb
        kd5fnbxyl@arkd.not
Offline gregb
  • Pinto Driver
  • FeedBack: +0/-0
Re: 71 motor swap
« Reply #4 on: February 10, 2007, 07:47:19 AM »
Did you ever find out if the 1.6 and 2.0 had the same tranny bolt pattern?
Offline Blacksheep22
  • Pinto Member
  • FeedBack: +0/-0
  • Gender: Male
Re: 71 motor swap
« Reply #5 on: February 10, 2007, 07:00:34 PM »
See Pintony's Reply in 1.6 interchagabili ty in this section.
71 Pinto Mini-Stock 1994 Track Champion
72 Pinto all original 63000
73 Pinto Wagon 2.0  4 Speed 8inch
