Date: 04/04/2020 09:38 am
1980 Pinto w/ Trunk
Date: 08/10/2022 04:09 pm
Date: 07/13/2018 02:21 pm
Date: 11/08/2020 02:10 pm
Date: 11/29/2018 10:26 am
1976 Squire wagon
Date: 09/12/2018 10:30 pm
Date: 04/15/2017 05:14 pm
1971 2.0 valve cover
Date: 01/25/2019 07:09 pm
turbo 4 cyl and aod trans
Date: 12/14/2019 04:55 pm
  • Online today: 586
  • Guests: 123
  • Total: 123
1972 front coil springs
Started by j1tuck, October 31, 2024, 01:11:42 PM
Quote from: TIGGER on November 19, 2024, 08:59:47 PM
I want to say I have later Pinto springs in my 73.  I did cut them though to get the ride height I desired.  Maybe someone else can chime in.
That's what I did. 1977 springs in my '72 and cut them to get the ride height I wanted.
It is a bit of work but Moog has a spring catalog. You MIGHT find a similar length, wire size, weight intended spring. I know that 71-73 front ends are different but 74 and up springs might be close but likely elevate the car in the front (because they carry extra weight) and cutting the spring to lower it back down stiffens it (even more). For $ I hear that springs can be made to order. Pinto's (early Pinto's in particular) are very much becoming a 'hunt, adapt, R&D, test' situation to keep them on the road. MAYBE you can find a rare NOS set out there in the wild - but I wouldn't count on it.
The rear leaf springs can be re-arced. But they are known to break even in general use so that might be done with caution.
Here is one source advertising 1972 springs, there may be others.  Suggest contacting them to see if it changes ride height or ride.https://racerwalsh.com/product-category/suspension/pinto-71-73/front-coil-springs-pinto-71-73/
j1tuck
cant find new springs for a 72 only 74 and up.
were can i get springs
