  • Online today: 586
  • Guests: 118
  • Total: 118
thoughts/opinions
Started by PintoMan1, August 28, 2024, 11:22:13 AM
PintoMan1
I hear ya! I probably would have needed it here to, but I'm not driving it anymore this season. But I feel better about just doing the job right.
1973 pinto runabout
rob289c
Good to hear...I have needed my defroster in the Upstate NY area the last two mornings!
rob289c
PintoMan1
update: I went the route of just putting in the new core. All back together and doing fine.
1973 pinto runabout
rob289c
If it's apart and you have the new core, I suggest installing it and put it back together...
rob289c
PintoMan1
I'm in the southeastern part. Just south of Allentown.
I'm not sure as to what I may do here. I do have it all apart now, just wanting to get it all back together. Hunting season is starting soon and I won't have time after that. I may end up just bypassing for now until spring. Just need to have something to be able to run it though out the winter. As I said earlier, I don't drive it in the winter months. Driving season for me is over anyway, starting to get cool now.
I'll keep up to date as to what I do (sitting on the fence). I do appreciate all the feedback. Thanks!
1973 pinto runabout
Creedmoor
Won't hurt a thing.   1980 Pony SE. Heater core replacement sucks.  Snows a lot during the winter here. Pintos don't do well in the snow   Only drive mine during the spring/summer/fall. Bypassed my heater core a couple years ago. No ill effects and no more coolant in the passenger footwell.
rob289c
If you have a new one I wouldn't even bother testing the old one.  You should never have to mess with this again once the new one is installed.
Where are you in PA?  I used to line in Middleburg.  Near Selinsgrove, Sunbury, Lewisburg, Mifflinburg.
rob289c
PintoMan1
I decided to just get a new core (till I can have the one I have tested). I have it all apart now so why not. Got new hoses while I was at it.
And, Yes, it is not an easy job. Especially when you are trying not to break anything.
Thanks everyone for the input/help.
1973 pinto runabout
rob289c
The consensus is that overheating shouldn't be an issue if you eliminate the heater core, provided all your cooling system components are up to snuff.  If they weren't you would have overheating issues with or without the heater core.  If you decide to go with an electric fan, you may find that your current alternator may not be up to the task and may need to upgrade to a higher amperage unit.  It may bring a quicker death to a marginal alternator.  It is a good upgrade that won't hurt anything if you get the right kit, install it properly, and have a stout enough alternator.
My opinion:  install a new heater core.  While it isn't a "fun" job, it's a snap compared to modern vehicles, and you can get one from Rock Auto inexpensively.  Sometimes in the Spring or Fall when using the defroster, you will appreciate having a little warmer air to keep the windshield clear.  Not to mention, if you have a wife or GF, they tend to get cold even when we are sweating...
My $.02...
rob289c
PintoMan1
Thanks! I read that it could cause over heating if I was to run without it. In that case, would it be beneficial to add an electric fan to help in cooling?
1973 pinto runabout
HOSS429
i had a 55 chevy built for sale in the south that did not come with a heater .. your car will not know the difference ..
PintoMan1
Thanks for your input. I'm not sure if the core is even bad or not, just got it out and haven't had it checked yet. I did have a very small leak and I do mean small leak after running. Temperature gauge never got hot or over heated. I did notice on the hose coming from the core neck coming from or going to the carb was a little wet. I'm thinking (until I can have the core tested) that the hose is bad (at the clamp). Of course, it has been 19 years since I had it flushed, cleaned and repaired (only have 3,100 miles on it). I live here in Pa. I don't drive it at all in the winter (other than starting once a month to keep things in check). I mostly drive it in the summer months (and that depends on the weather).
1973 pinto runabout
Most of the time when this is asked it is because the core is leaking. The two negatives I can see is IF the car got hot in the summer you would not have the brief advantage of flowing the coolant through the core. I say brief because in theory it should be cooler than the hot coolant temperature, but shortly after mixing that advantage will be lost. I doubt the actual cooling capacity of the core itself contributes much to engine cooling and remember all that heat would be going into the drivers compartment!  The other negative is dealing with condensation on the interior glass. That would be dependent upon your climate.
PintoMan1
I would like to get some thoughts and opinions on maybe bypassing the heater core. what are the pros and cons of doing this? I do not drive the car in the winter, so no heater needed. But what are the pros and cons of running like this in the summer? Thanks!
1973 pinto runabout
