FLOOR PANS
Date: 06/12/2020 07:24 pm
Date: 09/10/2018 10:41 pm
Offenhauser 6114 dp
Date: 09/12/2017 10:26 pm
2.3 turbo intake (lower)
Date: 07/15/2020 09:29 pm
Date: 02/14/2019 06:27 pm
1980 Pinto Parts
Date: 08/05/2020 04:20 pm
Date: 01/24/2021 07:54 pm
Date: 12/10/2016 04:11 pm
Date: 06/22/2017 07:19 am
  • Online today: 128
  • Guests: 95
  • Total: 95
What is This Part?
Started by rob289c, June 22, 2024, 05:23:26 PM
rob289c
Can someone tell me what the tube in the center is for?  It's the S-Shaped one to the right of the window on the left. It looks like it may be for vacuum?  Vacuum modulator?  The other two are the transmission lines to the radiator.
Hopefully someone will be able to identify it for me.  Thank you in advance.
rob289c
rob289c
I think I know why I am confused.  When I sectioned the cowl, it moved the dash forward roughly 8" so the orange bracket I asked about no longer fits where it was in the factory position.  I have the other one in the pic below that I cut apart and re-welded to alter it that I am going to have to use in place of the orange one.  I'm not exactly sure how it originally mounted.  The 2nd pic is an attempt to show how narrow the cowl is now and how far forward the dash will be from its factory position.  Sectioning the cowl not only created a lot of extra work, but also a lot of "re-engineering" to mount other parts and components and other alterations to make things work.
rob289c
I thought I had a picture on this home computer showing the brackets spot welded to  the trans hump. Must be on my lap top in the shop.
That part is bolted to these brackets & the bottom of the dash. Then a plastic sort of an open cubby hole for stuff.
rob289c
Thank you all for the answers!  I will look it over when I get home.  There is another piece that I thought suited that purpose that I was going to use...I'll post that pic later.  My dash is modified and the part I posted may no longer fit for my application.  I will report my findings.  Thanks again.
rob289c
Quote from: PintoMan1 on June 22, 2024, 10:09:17 PM
that is what it is for. and yes, it is upside down in your picture.
X2 on that. It also provides a bit of rigidity to the dash. Not much Pinto stuff out there. It took about 20 minutes to find a picture that kinda/sorta shows where it goes. First pic found on internet. Second pic
is bracket in my car. I use a Murkur XR4Ti center console so the factory unit is not installed (fuse block is from the Turbo Coupe - in case anyone wondered). It does seem that not only is the outer section upside down but the inner section needs to rotate 180 degrees - I think.
PintoMan1
1973 pinto runabout
Mattb
Perhaps the mounting bracket for the console that mounts below the center of the dash in front of the gear selector.
rob289c
I can't remember where on the car this came from.  The pic below may be upside down.  It appears I cut some spot welds to remove it.  It doesn't seem to fit on the trans hump.  Not wide enough to fit over the hump.  I'd like to know what it is and where it came from on the car so I can decide if I need it or not.  Thank you in advance.
rob289c
