71,72 Pinto Door Panels
Date: 06/17/2018 08:27 pm
Date: 07/08/2022 11:51 pm
1976 Ford Pinto
Date: 07/16/2019 02:51 am
1976 Squire wagon
Date: 09/12/2018 10:30 pm
Pinto for sale
Date: 04/19/2017 10:15 am
78-80 Windshield
Date: 10/29/2021 03:11 pm
hood for a 79-80
Date: 11/30/2018 10:55 pm
pinto floor mats??
Date: 01/11/2017 07:27 am
Date: 10/03/2018 02:00 pm
  • Online today: 586
  • Guests: 115
  • Total: 115
1971-73 2.0 motor mounts
Started by LongTimeFordMan, May 17, 2024, 09:27:39 PM
It looks like it will do the job. The alignment pin might have only been there to assist for assembly to keep it from falling off. As in, one person places it on the bracket and another person tightens it. Or it might be there for anti rotation when it is being tightened.
BTW, I don't remember bolts on the metal engine mount. My recollection was that I had to cut mine out because they were welded. and when I went to the 2.3 I had to get 74-up brackets and weld them in too.
LongTimeFordMan
Wellll...
The 2429 mounts fit... they are about 1/4" taller than old mounts, not sure how they would compare to new oem.
I cut off the alighment pins on the 2429 and because the studs on the 2429 were on the same.axis and the oem were offset i used the aux hole (the one for the safety cable, zoom in to see holes)  in the engine side mount and the 2429 seemed to line up with a bit of massaging
Heres a pic of the 2429 installed on driver side.
Still seems feasible to me. If you wanted to retain the metal part of the original mount you could notch the rubber with an angle grinder and a coarse disc.
LongTimeFordMan
I found a universal industrial type mount # 2429 available multiple places including autozone, amazon, etc for about $ 7-9.
Only difference is that it has no metal shield and the mounting studs are in the same axis rather than the slight offset on the factory ones and are a bit larger diameter bit same height.
Rock Auto seems to be "Out of Stock" on all the mounts though they list five different types. From what I can see they are a standard round mount with the exception of the safety wire and the half surround on the metal base. You MIGHT be able to find an industrial intended mount of similar size and fit it into a gutted stock mount.
Regarding the polyurethane most I saw stated around a 150-180 degrees limit. On my Corvair being air cooled vast quantities of air are constantly being drawn into the engine compartment so for me it was less concern.
alwaysFlOoReD
Some ford rangers with the 4.0l engine had torque limiting "shock absorbers" on the drivers side. Early 90's. That might be simpler.
LongTimeFordMan
Thanks for the info...
I found the Smooth On and spoke to a rep and that was one of the resins i was considering..
He mentioned.considerations about heat so i measured the temps of the mounts after driving about half an hour in 90 degree weather i measured 145 degrees on driver side and about 200-210 passenger side under the exhaust manifold.
After some research, i found these options for universal motor mounts
https://www.autozone.com/external-engine/motor-mount/p/duralast-engine-mount-2123/154237_0_0?vehicleId=1409201
https://www.autozone.com/external-engine/motor-mount/p/duralast-motor-mount-2429/108977_0_0?vehicleId=1409201
And i think i might try adapting one of these since they are rubber and one has mounting stud
molded in. And i thought about drilling the studded one and adding a "safety" bolt to replace the canle in the factory mount to limit stretching on the driver side which is under torsion load.
The other might be good for soms sort of bolt thru sandwich arrangement.
rob289c
Interesting read.  Nice job, and good luck to anyone that takes on the challenge.
rob289c
Interesting..., I have just been going through this with my Corvair Station Wagon. The trans/differential has two mounts roughly 2" x 2-1/2" circular. They are $170 for the pair!!! After investigating the Polyurethane method I came to find that it comes in many hardness's and within the hardness factor there are numerous scales that they are measured on.  Shore Hardness A seems to be the appropriate scale.
Shore Hardness A as it applies to factory motor mounts can be anywhere from 40-50. 60 is commonly sold as stiffer upgrade. Then you get these people who go all the way to 94 which is like solid steel. Smooth On is one of the big suppliers of the Poly and they have a chart that helps you understand. https://www.smooth-on.com/page/durometer-shore-hardness-scale/
Because most motor mounts are primarily compressible (downward, at an angle) the 2 part Poly should do well. In the case of my Corvair they are vertical and housed in a 2" tube with a center bolt. Because adhesion was paramount I opted for another product. The regular Poly can shrink and I would lose bond in the tube. Thus I opted to use 3M Windo-Weld 08609. This had adhesion properties to strongly bind a windshield to the car but is still a Poly product with a Shore A hardness of 55-60. The only down side is that it is a 1 part moisture cured product. I had to put it in in 1/8" thick layers (that would we 12 layers) two hours apart and it was a 24 hour all night affair. While cheaper than buying new mounts the stuff isn't as inexpensive as many state. They are often sold in "Starter Kits" otherwise you are buying gallons. Tax and shipping pushes the kits into the $40 range. My Window-Weld was 10.5 Oz. and was $33 with tax (free Amazon shipping). I used two thirds of the tube on my two mounts.
Anyway, sorry I don't have any 2.0 mounts for you to test with but hopefully the Poly information is helpful. I've included a before/after picture of my Corvair mounts as inspiration.
LongTimeFordMan
1971-73 2.0 engine mounts.
I've been looking for a source for motor mounts for my 73  2.0 wagon and it seems that all of the NOS is gone.
I have been researching rebuilding mounts from urethane resin but need a few pairs to experiment with.
If anyone has any worn out mounts I would be willing to buy them to experiment with.  If i am successful in finding a method to refurbish them i will post instructions.
Not sure how to receive responses so just post them as comments and i will try to send my contact info.
Thanks Ed
