Oddsnends
Date: 12/20/2016 10:52 am
Date: 03/13/2021 12:57 pm
McLeod Clutch
Date: 04/12/2017 12:08 pm
1970-1973 Gas Tank/Blue Dash
Date: 02/07/2019 11:57 pm
1976 pinto for sale
Date: 01/12/2017 02:08 pm
74 Pinto wagon armrests
Date: 01/18/2017 07:04 pm
Date: 04/06/2017 12:13 am
Pinto hubcap
Date: 01/07/2017 08:40 pm
convert to stick
Date: 05/19/2018 09:26 pm
  • Online today: 586
  • Guests: 452
  • Total: 452
Pinto Parts On Amazon
Started by BigHoss48192, April 21, 2023, 06:16:37 PM
What a nice list!  Thanks for sharing... it's bound to save some folks a lot of time and trouble.
Dwayne :)
BigHoss48192
Hatchback/Sedan Gas Tank  https://amzn.to/3L3U8U4
Gas Tank Straps https://amzn.to/3A5nU4w
Filler Neck Grommett https://amzn.to/43w87JL
Fuel Vapor Seal https://amzn.to/3MJGsPl
Fuel Tank Vent https://amzn.to/3GNknfg
Fuel Sending Unit w/ Return Line  https://amzn.to/43F10i0
Fuel Sending Unit w/o Return Line  https://amzn.to/43AKi3q
Carpet  https://amzn.to/3L46T11
Power Rack & Pinion  https://amzn.to/3UJzgF8
Manual Rack & Pinion  https://amzn.to/41eiFM3
Upper/Lower Tubular Control Arms  https://amzn.to/3mAD4Mf
Rear Brake Drums https://amzn.to/3o9hC14
Shocks https://amzn.to/3og8Bn1
Starter https://amzn.to/3KHKa9D
Rocker Arm Followers https://amzn.to/3KFe1iY
71-78 Dash Cap https://amzn.to/3ocBNLD
79/80 Dash Cap https://amzn.to/3GN4UvF
Door Lock Cylinders https://amzn.to/40bT6dg
2" Drop Spindles https://amzn.to/43GbjT
Hatch lift shocks https://amzn.to/3V1lhdY
Timing Belt https://amzn.to/3L0mCgb
Front Left & Right Bearings/Seals https://amzn.to/3UVzsBc
Inner Tie Rod Ends https://amzn.to/3oBXGnI
Outer Tie Rod Ends https://amzn.to/40wxDMj
Turn Signal Switch https://amzn.to/3H7f8XU
Rear Brake Shoes https://amzn.to/40KFHct
Floor Mats https://amzn.to/3N4Pp6c
Hatch Window Gasket https://amzn.to/3KQhOde
Trunk Weatherstrip https://amzn.to/3AiXSLh
Door Latch Assembly Driver https://amzn.to/41MMFhY
Door Latch Assembly Passenger https://amzn.to/3UZnBC1
