Date: 05/15/2022 11:36 am
Date: 11/23/2017 05:44 pm
Date: 06/18/2018 03:47 pm
Anyone scrapping a 1980
Date: 03/13/2020 08:46 pm
1980 Ford Pinto For Sale
Date: 07/01/2018 03:21 pm
Date: 12/26/2016 04:29 pm
71-73 sway bar
Date: 06/12/2021 10:12 am
Date: 04/12/2017 06:57 pm
1973 Pangra
Date: 01/06/2015 02:19 pm
  • Online today: 586
  • Guests: 122
  • Total: 122
C3 pan
Started by 2point3, March 04, 2019, 12:20:19 PM
Being the C-3 was never considered a performance transmission I'm doubtful anyone ever made a deeper version. Some things to consider are ground clearance. Pinto's, especially with 13" tires, are rather short, and a deeper pan might wind up becoming a damaged pan. Also, unless you lower the pick up point (that unfortunately is typically built into the valve body) you haven't gained anything if fluid starvation is a problem.
As large a trans cooler as can be accommodated might be a better route. It will increase fluid volume and since heat (breaking down he fluid properties) is typically a high cause of  transmission failure you get that added benefit as well.
Otherwise you probably need to find a junkyard that has a car with an existing C-3 pan and modify it yourself.
2point3
I want to purchase a deep pan for my 1980 C3 transmission. No luck, so far in finding one. Can anybody steer me in the right direction, or, tell me where I can find a stock C3 pan that I might be able to rework?
