Clutch pedal needed
Date: 01/11/2024 06:31 am
Date: 07/17/2018 09:22 pm
74 hood
Date: 07/03/2017 03:46 pm
1980 Pinto-Shay for sale
Date: 07/07/2016 01:21 pm
pinto for sale
Date: 09/11/2016 09:47 pm
Date: 02/16/2019 10:46 am
1978 Squire wagon 6 Cly
Date: 03/08/2021 10:44 am
Mallory Unilight dist 2.0
Date: 10/25/2019 03:44 pm
Crankshaft Pulley
Date: 10/01/2018 05:00 pm
  • Online today: 586
  • Guests: 130
  • Total: 130
T9 Good to Install for a Performance '72 122c.i./2.0?
Started by Bret Culpepper, December 10, 2018, 01:44:35 AM
No, it probably won't be. The stock 2.0 that was in my car liked to wind up. 2200 is at the bottom range of usable with the larger 2.3T that replaced it. Same with my '04 Tacoma 2.4.
2.0s are known for having intake ports that are, aside from being sub-optimally shaped, already too big for the engine. It makes the low-end rather soft in cruising RPMs.
Henrius
Quote from: Wittsend on November 19, 2019, 02:51:22 PM
You also have to weight if in everyday driving the 2.0 and a 5 speed are a good match. Some here have said no.  The 2.0 when it makes more power tends to make it in the higher RPM range. On a race track where you are moving at speed that is OK but in everyday driving it might be a hindrance.
  https://www.youtube.com/watch?v=sI6mCjQ2gO0
This quote made me think. So I fired up my 1973 Pinto with a 2.0, increased compression ratio and headers, drove it around making sharp accelerations from stops. I compared it to my 2006 Corolla 5 speed.
The Toyota 1.8L generates lots more torque at low RPMs. The author is right. The Ford 2.0 has to be wound up to higher RPM before it really generates the torque. So I wonder if hiway cruising at 2200 RPM is really practical in the Pinto like it is in my Corolla.
1973 Pinto Runabout with upgraded 2.0 liter & 4 speed, and factory sunroof. My first car, now restored, and better than it was when it rolled off the assembly line!
At this point I wouldn't even be committed to a Ford engine.
The 2.3 is old to the point that a lot of mass appeal and availability has waned, I think to Wittsend's point. Fancy parts are still available new, but only from select few vendors and certainly not low prices. That was always the 2.3T's appeal; it was cheap to make fast.
I think I last stumbled on a CL listing for a T9 five years ago. It was quite ugly and they wanted a bunch of money with no indication of condition.
I surely understand stepping up to the the challenge. And it is nice to 'do something different.' Unfortunately sometimes the cost vs the return on that cost is hard to justify. While still not available in great numbers there is the T-5 from the 2.3 Fords. You would be more likely to find that. Hopefully someone will correct me if I'm wrong but I believe the 2.0 has two sets of upper bolt holes and the 2.3/T-5 bellhousing will bolt on? It does require more modifications though.
At this point I think the Duratec engine (however one can make it fit - if it will fit) is the future. If I was younger and more ambitious I think I'd try and tackle that. If anyone is familiar with Urchfab on You Tube he adapted a Ford E105 to a Miata unibody substructure.
Henrius
This may totally impractical, but give it a thought. In Europe, particularly England, these 2 Liter cars were much more possible. I have always dreamed of a David Vizard reworked head on my engine. How practical would it be to import something from Europe like a cylinder head or a rebuilt T-9 transmission? How would it be possible to ship?
  I've noticed that we in Pinto-dom tend to talk about parts that are difficult, if not impossible to find (without mentioning that). And to someone who doesn't know, Id think they would assume the parts are readily available - when they are not.
Just recently it became know how difficult it is to find windshields. Then there are gear sets for the smaller 6-3/4" rear end. My own experience with Turbo Coupes is that I haven't seen one in a junk yard for well over 5 years. A Merkur..., it has probable been 10 years.  After an absence of a number of years I did stumble upon four in a Pick A Part (again about 10 years ago) but the forklift was cleaning out the row as I was contemplating if there was anything I wanted. That was the last time I saw one. And this is in sunny So. Cal. where cars linger longer and should be more readily available.
Yes, there was a time when these cars were more available. In 2007 I'd see 3-5 Turbo Coupes and a Merkur every month when I went to Pick Your Parts 50% off sales. But it seemed within 6 months that diminished. A few years later they were a rare sighting. So, I hope I don't come across as scolding anyone (I'm not trying to) but I feel when we give out information that these parts exist we need to also mention the difficulty in finding them.
I've been searching for an 80-86 Jeep T-178 transmission (Toploader) for my Sunbeam Tiger for nearly 20 years.  It has an every so slightly wider ratio than the wide ratio Toploader which today is a $1,200+ transmission.  I was hoping to find one at Pick Your Part for $150. The Jeep people always want the granny gear T-176/T-177 transmissions and I thought it would be an easy find - NOPE.
PintoMan1
Quote from: Henrius on November 18, 2019, 04:31:44 PM
Where did you find that T-9? I have been looking for one for the longest time.
me as well almost 10 years I've been looking!!
1973 pinto runabout
Henrius
They were factory gearboxes behind turbo 2.3s in the Merkur XR4Ti. That engine easily made 160hp/220ft-lbs at the wheels with just exhaust, which is probably 50-60% more than your 2.0 with basic mods.
I wouldn't worry about it.
robertwwithee
I agree as well
Rebolting73
Hi Bret, once installed a T9 will hold up just fine with your modified 2.0.
Bret Culpepper
Salutations Y'all;
I've searched the Entire site & couldn't find an answer.
My '72 122c.i./2.0 has installed a Blackjack Header, a Weiand Intake, along w/ the 390c.f.m. Holley designed for the 122c.i./2.0.
I've found a standard T9 & know about it's weaknesses, but will there be a Problem  w/ installing the T9 w/ the above Performance Parts?
