Date: 08/09/2018 07:49 am
Date: 10/31/2018 12:04 pm
1971-74 Various Pinto Parts
Date: 01/18/2020 03:44 pm
1972 Pinto SCCA BS race car
Date: 10/23/2018 04:01 pm
Looking for front seats
Date: 08/10/2021 09:54 pm
Cruiser Dash Gauges
Date: 12/04/2016 11:50 am
Date: 05/21/2019 11:50 am
Date: 05/22/2018 02:27 pm
79-80 full glass hatch
Date: 01/04/2017 04:04 am
  • Online today: 586
  • Guests: 443
  • Total: 443
2.0 turbo
Started by Pintocrazed, October 27, 2014, 07:43:30 AM
Quote from: Pintocrazed on October 28, 2014, 06:05:00 PM
That's the problem I have no idea what I'm doing.ive never had a turbo motor
Then......bad idea.
Quote from: Pintocrazed on October 28, 2014, 08:59:09 PM
How much fun is it driving with the 2.3 turbo?
It's hard to describe. Mine black tracks going into 3rd gear with no clutch antics and it has the lowest-rated non-intercooled 2.3T with the largest, slowest-spooling turbo they came with. It's not what I'm accustomed to nor what I expected...it's more.
Quote from: Wittsend on October 29, 2014, 01:32:52 PM
"I NEED A 2.3 TURBO THEN"
No..., you need a donor car, an engine hoist, the capabilities to weld and fabricate sheet metal for installing the motor mounts and engine compartment alteration. You will need a transmission capable of handling the power output. You will need (at least should) have an 8" rearend. You will need (at least should have) a larger radiator. You will need an external high pressure fuel pump.
Lastly you will need 200 to 400 hours to do this right. Yes, there are people who say the did it in a weekend but they probably had a '74 and up car, knowledgeable friends helping and all the parts ready to go. The car was probably "functional" but likely far from proper.
Don't assume you can just drop a turbo on an engine or simple slide a turbo engine into a Pinto (especially and early one).
To answer your question: just about any turbo motor should have forged pistons. The 2.3 Turbo motors came with forged pistons and a compression ratio conducive to the turbo boost.
THIS ^
I knew six months ago what I know now, I would have started with a factory 2.3 Pinto.
Well a 2.0 never came with a turbo (not counting the AK Miller) so you will have to fabricate everything. Everything.  A carb'ed turbo is a nightmare so ideally you need a fuel injection system to make it reliable and drivable. Can it be done? Sure it can. But it's not as simple as bolting a turbo on the engine. Even a 2.3 swap with a doner car is a good deal of work.
Pintocrazed
WELL I WAS TRYING TO KEEP IT  A FACTORY 2.O BESIDES BEING BORED .30 OVER AN TURBO.ANYBODY KNOW IF ITS A BAD IDEA TO BORE IT AN RUN A TURBO?IVE NEVER BUILT A MOTOR FOR PERFORMANCE SO I HAVE NO KNOWLEDGE
Pintocrazed
The pistons need to be forged...................
Pintocrazed
Better than sex......
Pintocrazed
Your honesty probably saved you a bunch of grief.  The most advisable method to running a turbo motor is to transplant from one of the 2.3 turbo cars (using a whole donor car).  65Shelby Clone is in the process on doing one now and you can follow his work (on page 4 now). http://www.fordpinto.com/index.php?topic=24739.0  A search will show other as well.
I did the 2.3 turbo swap in my 2.0 '73 wagon.  Here is my two part write up.
http://www.fordpinto.com/general-pinto-talk/so-you-want-to-build-a-turbo-pinto-part-1/msg76893/#msg76893
http://www.fordpinto.com/general-pinto-talk/so-you-want-to-build-a-turbo-pinto-part-2/msg76894/?topicseen#msg76894
Pintocrazed
Depends on how well you know what you're doing.
Pintocrazed
I have a 73 runabout got .30 over pistons for my 2.0  and thinking about running a turbo from a turbo coupe.good idea or bad idea?
