Date: 05/22/2018 02:27 pm
72 Pinto parts
Date: 11/14/2019 10:46 pm
74 & Up Parts
Date: 01/20/2021 03:22 pm
Date: 10/05/2017 02:26 pm
Date: 01/12/2019 10:19 am
74 Pinto wagon armrests
Date: 01/18/2017 07:04 pm
78 pinto wagon
Date: 06/04/2020 12:42 pm
Date: 10/03/2018 10:46 pm
Date: 04/08/2018 05:47 pm
  • Online today: 500
  • Guests: 446
  • Total: 446
rubbing tires
Started by dumcheesemonkey, August 02, 2014, 09:18:44 PM
It's probably just rubbing on the plastic inner liner. If you don't drive in snow & salt take them out.
PintoMan1
I have 185/60/14 on front with a 2" drop and no rub at all.
1973 pinto runabout
I run 195/60/14's in front when I can. The 175/70/14 you have is a slightly taller/thinner tire and I can see that rubbing on some Pinto's. Even the 195/60/14's I run will rub at times... depends on the Pinto I have them mounted on (some will sit higher than others) backing up and sharp turns.
could try 195 or 185 - 60's (wider and shorter) or 165/70/14
dumcheesemonkey
79 wagon 2.3
what size are the front tires?
dumcheesemonkey
if thats it thatd be great, i was planning on doing the ball joints, bearings, pads, and rotors coming up pretty soon
79 wagon 2.3
derekrichmond15@yahoo.com
Or bad ball joint jack up car and c if you can wigle the tire I'm going with this or the tier is bigger o snap it could b bad wheel Barings well that's all I can think of good luck!!
1977 408W stroked pinto
Could be evidence of a dead/dying bushing somewhere as well.
the tire is probably slightly larger than your old one, even if it has the same markings.
Just like with clothes, even though they use the same sizing, it can be off just enough to cause problems.
If you only replaced the one tire, try swapping it to the other side and see if the rubbing follows. If it does then you are sure of the cause. If not, then something has happened to the driver's side suspension.
dumcheesemonkey
i recently got a new problem with my 79 wagon. when i got it back after winter i needed to replace the front drivers side tire. since then while in reverse and turning (depending on how far the wheel is turned) it now rubs the wheel well. not really sure why it started after the new tire but whatever. any ideas on why its doing this or know of a way to fix it?
79 wagon 2.3
