Date: 01/04/2017 04:07 am
pinto floor mats??
Date: 01/11/2017 07:27 am
Date: 02/03/2018 11:28 am
Pinto Watch
Date: 06/22/2019 07:16 pm
1971-73 2.0 motor moiunts
Date: 05/17/2024 09:18 pm
79 pinto small parts
Date: 04/24/2019 03:16 pm
Date: 06/30/2018 09:48 am
looking for parts
Date: 06/19/2020 02:32 pm
71-73 Pinto Parts
Date: 06/06/2019 10:47 am
  • Online today: 128
  • Guests: 70
  • Total: 70
A 1972 turbo swap adventure
Started by 65ShelbyClone, July 20, 2014, 12:39:02 PM
Thanks for the photos.  8) Yours looks almost like a factory install. I think I have it a little bit easier since my '86 harness only has one grommet. Most of the unused wires can also be reused or allocated  for extra fun EFI features like boost control, fan control, water injection, 2nd O2 sensor, flex fuel sensor, etc.
I just spent a bunch more money on parts. Driveshaft, u-joints, gaskets, bearings, oil, and I forget what else for now.
OK, here are the two firewall pictures where I went through the firewall.  As I said I used the '88 harness and took the, "what do I have to remove approach." In retrospect I should have probably taken the, "what do I need to keep approach."  Both the rubber grommets are factory. Even after I sifted though the ride control, A/C etc., etc., I had about 20 wire I was unsure of. I have since deleted most - after I got it running right.
Regardless it doesn't stay too pretty using all the factory stuff.  I guess it was just my fear of removing something I would need to be put back - but not being sure what "it" was.
I got it out of a '96-98 Mustang V6. They can be found in many other years and models from around '94+. The trick is finding one with the right case. My 3G has all the 1G mounting points, but the adjuster ear isn't threaded. It requires either a bolt and nut to hold it or possibly installing a 3/8" thread insert.
Quote from: Wittsend on August 07, 2014, 12:48:33 AM
1.) I used the dreaded '88 harness I had from the donor car. I put the ECU in the kick panel area just like the T-Bird.  I used the T-Bird Factory triangular shaped grommet and ran it in near the upper corner of the heater box.  Since your donor car is an '86 that may be all you need. BTW, after the Merkur harness I hear the '86 is desirable.
  I also had a round grommet and wires that I ran in about 3" from the factory Pinto passage.  Lastly, I used the T-Bird steering column and that added to the wire count.  I'll see if I can snap a few pictures tomorrow.
2.) And, yes, I almost went and looked at the Simi Valley car.  It was only about 8 miles away.  But, I've got too many project competing for my time and money.  Glad to see it is becoming a very nice car.
1.) Thanks for the run down. I will admit that I have not yet surveyed the interior for places to put the EFI harness. I am reluctant to make another big hole in the firewall. I wanted to put my ECU behind the console area and the big factory grommet looks to be close, so a round one like stock, but with two holes might make it easier to do.
I'm going to be using a MegaSquirt standalone ECU so the whole package will be about 40% smaller than the stock ECU/plug/harness.
2.) Thanks.  ;) It's going to get nicer. One of my goals after the swap is to respray it when the weather isn't too hot and before it gets too cool. Here in the high desert that typically gives me a 7-14 day window.  ::)
don33
what year/model car did you get that 130 amp jewel out of ?
Question for anyone else with a 2.3T swap, espeically in a '71-73 car: how did you handle running the EFI harness into the cabin?
Quote from: Reeves1 on August 06, 2014, 10:43:40 AM
Having the engine out will make it lighter for shipping me that nice car  ;D
You don't want it; it's rotten. See how green it is?
Quote from: Wittsend on August 06, 2014, 06:31:29 PM
I don't think I've ever seen your car before. Is that the green car that was on Craig's List in Simi Valley a number of months ago?
Sounds like the same one.
My first gear is the really steep 4.03 one, so the 3.00s won't be a problem taking off, but overdrive is going to be mostly useless.
I crunched the numbers manually and my car will do a scoche over 2600rpm at 65mph in 4th and about 2100 in 5th with 3.00s. 3.40 gears would bring that up to ~2450 in 5th and 3.55s would do about 2600. Decisions, decisions.
Here is my 130A Jewel of the Pile:
I took it apart to clean and repack the bearings, dress the commutator, and managed to break the brushes, so there's another $9 toward the project. At least it will be practically rebuilt and won't even break a sweat with the electric fan, lights, and EFI going.
And here is what I spent my evening doing:
When I first got my Turbo Pinto going I had the 3.00 with 215-60-14" tires. 65 MPH was about 2000 RPM.  The worst part was that for any given "legal" speed the gearing just seemed to be wrong. Up shifting bogged and down shifting was RPMs with little torque multiplication.
Eventually I got a 3.40 rear and am currently running 175-70-13".  For general driving it is MUCH better.  65 MPH is now about 2600 RPM.  I'm going to a slightly taller tire soon. I've got a pair of 205-60-13". I'm also looking at going back to 14" tires too.  I've got about four different wheel tires combinations to try between my Sunbeam Tiger and my Pinto.
I would like to go with 3.40 or 3.55 gears and a T-Lok. For now it's going to get used as it is. The legs are going to be pretty long with overdrive.
don33
they did go into production, I had one, same 3.00, out of a 67 falcon. found it in a jy. but anyway, that's neither here nor there. you going to put a spool or something in it ? change the ratio ?
It's just a common 3.00 open diff. OEM 8in Traction-Lok carriers are like hen's teeth. In fact, I'm not sure Ford ever used them in production.
It needs a pinion seal too. Fortunately I have another 8in rear that doesn't, so I may swap the third members when I'm replacing the axle bearings and seals.
don33
nice 8", what ratio is it ?  trac lock ?
In other news, part of a Mustang II Mach 1 headed for certain death will instead better the life my Pinto.
That sounds like DRHaulsee. He has a fleet of nice Euro Capris, including one with a Volvo head. Thanks for the lead, it gives me more to go by as I further wear out TF's search engine.  ;D
In other news, I didn't like my first alternator bracket. It seemed kind of flexy, so I rebuilt it with more substantial material. Then I mocked-up the belt and it hit the lower bolts. Then I found out the spacers I made just happened to allow the adjuster to be run behind the lower bracket, so now only one bolt is in the way. I think I can shave the head down and make it work or countersink the bracket and use a different bolt.
Quote from: turbopinto72 on July 23, 2014, 01:37:38 PM
What kind of info do you need on " that car " ?
Specifically: perhaps what was done to adapt the 4.6L elbow to the lower intake and how well it worked. It looks like new holes were put in the flange it was bolted to a square EFI lower.
Generally: maybe a rundown of the mods and how the car performed. I thought it was your Pinto and tried searching, but the most Icould easily find was the picture I posted and a smaller one like it on bob2000.com
don33
I plan on redesigning my under hood plumbing in the future. I will use a different header, one that tilts the turbo more towards the fender and a bit lower. on the intake side, instead of the upper mounted on top, it will be mounted on the side towards the fender. I have kind of mocked it up like that and it will all fit under a stock hood.  ;D.....   but back to your setup. I think one of the guys on TF used that piece on his euro capri and it worked well. so I see no problems on your setup.
Tomayto, tomahto.  ;)
Anyway, this is the thing I bought:
in order to make a setup reminiscent of this one:
I wish I could find more information on that car.
don33
Says you with an ARCA head, Holset turbo, and 900hp fuel system.  ;)
I wanted to go 3.00" out the back (do it right the first time is my mantra) and probably will in the future, but I have the parts now and am looking more at being able to drive the car soon. It's probably going to be 2.5" from the turbo down to a glasspack with a turndown facing down and to the side (ugly and loud, but at least I'll hear the turbine!  ;D). Something could change, though. This morning I thought I'd have to fabricate a whole upper intake. An hour ago I bought the throttle body and elbow setup from a 4.6 Mustang to use instead. :o It's kind of like a smaller, lower profile version of the Edelbrock elbow you were working with.
don33
open that exhaust up, 3" mandrill bent down pipe and exhaust...!  you really will be glad you did.
More.
It's really tempting to cheap out and use the crush-bent stock 2.25" downpipe, but I'm probably going to use that mandrel u-bend in the back to make a 2.5" one.
It's not much to look at, but this is a 6061 dipstick plug. Two o-rings to seal and an interference fit at the top.
I went back and looked and I guess it came from Jonson Machine. Whether they built it or just sold it, I don't know. Could be a C-Line.
don33
Race engineering sells a pan I'm looking at, very similar to that.
It's looking good, good luck on the project..
Quote from: 65ShelbyClone on July 20, 2014, 12:39:02 PM
That is also where the 2.0's alternator is, so maybe a little less wiring to do too.
Oops, fixed.
I did manage to relocate the alternator today and all it took was modifying a 460 alternator bracket and making some spacers. Now I can strip off all those huge brackets on the other side.
Now I have to fit the dipstick, plug the old hole, put some of the EFI harness back, and it will be ready to come off the stand, which means bolting on the T5 and pulling the 2.0/four-speed out.
Quote from: don33 on July 20, 2014, 04:15:13 PM
NICE.... I really like that oil pan, did you mod a stock one or buy it ?
Thanks.  :) I bought it because there weren't any other Pinto pans and pickups for sale at the time. Supposedly it came from a 2.3 engine builder/race shop. It's actually built from what was originally a rear-sump pan.
It was also cracked next to the welds in the rear end seal corners and I didn't notice until I had wet sealer and new gaskets laying on the block.  >:( It's fixed now; I just hope it stays fixed. If nothing else, it's a good shelf for storing loose bolts.
No photos, but I had to swap two of the main bolts to get a studded one in the right place for that pickup. The bearings looked really good on #4, so hopefully the rest are. I was going to pull all the rod caps and have a look, but decided I didn't want to know. I made the 'Bird run before I pulled the engine and it sounded/acted normal for burning seven year-old gas, so that's enough for now.
Quote from: Wittsend on July 20, 2014, 05:49:12 PM
Been there, done that. The 87-88 electrical is a real joy (see pics). Your work is exceptionally nice.  I also noticed your motor mounts and large (wide) sump oil pan.  All the best in your venture.
Look at all that spare wire though! And you got the dash out of there too. I started breaking things just to get the engine harness out...
For engine mounts I'm planning to use the stock 2.3T engine brackets, Speedway Motors universal isolators, and make my own frame brackets.
Looks like it's coming along nicely!  Keep up the good work!
Dwayne :)
