Date: 10/15/2017 10:03 am
front end parts
Date: 03/30/2018 12:48 pm
Date: 05/03/2024 05:37 am
WTB Cruising Wagon
Date: 12/07/2016 05:35 pm
Date: 10/25/2019 04:05 pm
Date: 04/07/2021 06:12 pm
Looking for a few parts - TIA
Date: 02/19/2023 12:18 pm
I need a 1976 hood
Date: 12/19/2016 06:02 pm
Date: 02/18/2017 05:55 pm
  • Online today: 563
  • Guests: 289
  • Total: 289
Blue 72
Started by Reeves1, April 15, 2012, 11:45:09 AM
dianne
Vehicles:
- 1976 Mustang II mini-stock
- 1978 Mustang King Cobra II
- 1979 Ford Pinto Runabout
- 1986 Chevy K5 Blazer
- 1997 Suzuki Marauder
dianne
That is soooo ugly! I mean real ugly, I will take it off your hands and send it to me ahahaha
WOW, I need one!!!! Nice, very nice Reeves!!!
Vehicles:
Had some time this morning , before returning to the grind......
Before :
I had it soda blasted. It took the blue paint off of the word FORD. Was just a little bit cleaner. Not clean enough by a long shot.
Set up my small sand blaster to use Walnut - didn't do anything.
So, since I have two......I sand blasted it.
It's blown off with air - will need a power wash.
After:
Worked awesome ! Not afraid to do so again ! LOL !
Right rad support done.
dianne
You can boost it also. I plan on twin turbos, all in time of course, but as they say it's all in the air flow in those heads and intake. You have the intakes though :D
Vehicles:
Still going to be a real cool ride..
Although I'm (trying) to build this one to 8.5 - it will not be that fast.
Engine will be a 302w roller block. Bore / stroke to 331. (likely a Scat stroker kit)
Solid roller (aggressive) cam & roller top end.
Want to run pump gas, so 10:1 or 10.5:1 compression.
Heads are 1969 closed chamber. Going to have them heavily ported & big valves.
Port & port match the vintage C90X - 9424 B intake, along with some plenum work.
Intake gaskets for the propane application to close off heat to the intake.
I already have the Holley 750 DP carb & MSD ignition (have to pick up a 6AL box though)
I already have a like new 9" diff housing. It will be narrowed, maybe Mark Williams axles & likely 4:30 gears.
I have a T-5. Going to have it re-built to as strong as it can be.
Just guessing, likely be in the 400 to 450 HP range ?
Just guessing, likely in the low 11s or with the right conditions , 10s ?
Going to hold onto this car till "the end".
B2 car will likely be sold when done & tested. Getting "long in the tooth" for a car that is going to be that fast.
Lots to do yet to this blue one.
First "plan" was to do the minimum to get it on the road.
Decided to chase all rust I am able to fix / replace.
Windshield cowl will be removed, along with the box below that.
Hope to have enough done by next summer to have the diff & cage built by a guy in Calgary.
dianne
WOW, almost as much as the Pro 4. That's gonna be an awesome frame. I'm building a 10 second car, maybe 11. I'll start with that and build over time if health and life allow it :) I need to break the 9 second mark in my lifetime though, that's on my bucket list.
You go Reeves, I'll live the 8 seconds through you for now!
Vehicles:
Dianne - google: 8.5 cert roll cage
You will find lot of pictures / info.
NHRA rules are the same everywhere.
Some of the attachment points in mine will be to also strengthen the sub frames I'm installing. Need this, as the springs will be connected to them.
My subs will extend out the back end about 1/4" past the body metal. I'm having solid steel blocks made to insert into the sub frames & weld in. They will be drilled in the center & tapped for at least a 1/2" bolt.
Reason: someone down the road may up the game with more engine & need chute attachment points.
Easier to do now, than after paint.
dianne
Quote from: Reeves1 on September 20, 2015, 03:16:43 PM
Aiming for an 8.5 cert cage & through the dash.
Want to keep the front bars as close to the front as I can.
Cage will be built by a guy in Calgary.
Same guy that will build my 9" diff.
The cage will be expensive. Are the tracks up there like the ones in the US? We have to have certain things at some seconds. I'm going to be building a 400 Stroker. Still learning, it's a LOT different than it was in the 70s for certain.
Do you have a design for the cage?
Vehicles:
For street & up to a 10 second 1/4 all you would need is a 6 point behind the seats - like my white car.
(I'm over building this blue one)
Floor plates have to be 6" x 6" and .125 thick. Rocker plates 6" x 2".
Google the newest NHRA rules. Easy down load. Keep as a pdf. I printed mine out.
76hotrodpinto
I'm not familiar with how they are graded, I just know I want to get a good one in mine too, for street use.
76hotrodpinto
How big of a cage are you putting in? Are you chopping thru your dash for full cage or just lower side bars to the front mounting areas you installed? I'm looking at doing this project too.
More time off = more done on the car.
Finished the front cage mount areas. Welded all inside seams on the trans tunnel. Repair / replace rust areas.
Front left rad support / inner fender had some rust issues.
Cut it out & replaced with new metal. 100 % welded seams.
The corner supports were rusted through. Made new ones. Got the left side done.
Rad support seams welded inside & out.
All work areas were sand blasted first.
Spray with primer to help prevent rust as the project goes along, till it goes for final blasting.
76hotrodpinto
Looks like your making great progress. I have the same plans for my floor pans, then more frame bracing. I can't get mine on a rotisserie, but I have a karmann ghia about to go up on it. Not mine, just a friends project.
Had a few days off & a few rain days off. Got some get ready for snow stuff at home done, as well as some work on the car.
Drivers side .125" plate is in. Still have to weld in the 6" x 2" plate on the rocker.
Although NHRA only requires a 6" x 6" plate for the cage, I wanted it to extend beyond that to replace the seam with rust & because I'm going to build torque boxes. Just because  ;D
It is also welded to the OEM frame rails.
I have a small patch to do at the top left of this plate. Will be done with thinner metal.
Also worked on the right side. Got the .125 plate in. Also three thinner metal sections to replace rusted areas. Some "gob" welds below the 3.5" 4" plate is to weld up a few small rust through spots.
Still have to weld in the 6" x 2" rocker plate.
All will be welded from under the car as well......when it goes on the rotisserie. Not sure when now......decided to do a lot more work / repairs than originally planned  :o
Again, the primer is only to help prevent rust from starting till it goes for the full blasting.
dianne
Quote from: Reeves1 on September 02, 2015, 09:00:11 PM
Actually more excited about this one than the B2 car.
Building this one from scratch is much more interesting, and fun.
B2 car is "tainted" ......due to the engine builds, and time lost on what should have been a 6 month upgrade. Lost 4 years on it. So far.
Yeah, I honestly can understand that! When I do one from scratch it's always better than buying one, more rewarding and fun!
Vehicles:
dianne
You're showing some awesome love to that car Reeves!!!
Vehicles:
Quote from: Reeves1 on August 16, 2015, 05:32:15 AM
Going to be slow going. Only times I can work on it is during slow times, like xmas, spring break etc.
Thank god I found a self storage that I can work in or nothing would be getting done on my cars for another year or two. This Tuesday my new 18x40 garage goes up which means I can actually get organized & have room to work at home.
Had a few days at home so got some welding done.
Sand blasted the edges of the welding areas inside & out for clean welds.
Changing gas from co2/argon to straight argon before welding next. Mixed gas plugs my lungs up bad for days. Cannot breath 4 - 7 days !
I put tape on the approximate locations of sub frames & cage plate areas.
I want to remove the seam under the heel location. So the plate is (a bit thicker) .125 and will be 6" x about 13". Will weld to floor, sub frame & rocker. A 2" x 6" plate also gets welded to the rocker & floor plates.
Will not be building torque boxes. Not enough front sub frame below the floor pan to bother with them.
Outside plates behind the seat will attach to the sub frames & rockers.
Behind the seat the center 2 tubes will be welded to the sub frames, as well as the 2 going back to the trunk area.
I'll get a guy I know in Calgary to do the cage, to make sure to will pass tech.
In the shot of interior you can see (surface) rust in the wheel well seam. All that will get sand blasted & welded, inside & out.
No more leak(s) and no need for seam sealer.
The floor seams that go from the rockers to trans tunnel have rust, but not through.
They will get cut out & replaced with a thicker metal (have to check on measurements for cage attachments specs for NHRA).
Going to build torque boxes, which will double for mounting locations for the cage.
Likely put it on the rotisserie this xmas , for all the blasting & epoxy primer etc.
Fire wall / trans tunnel cut out. Will cut a new hole for the wire harness after it's all welded back together.
I'll raise the lower rad hole then as well.
Battery tray area had rot. Cut out. Still need to pick up new metal to replace all that was cut out of the car.
How fast this car gets done depends on work.
Between the low & Global oil prices & the NDP getting in, the whole oil & gas sector has been slowing down.
Jobs are getting hard to find & it's predicted to get much worse.
Got more started.
Strut arms on the blue one were very rusty under the frame rubbers. Took the ones off of Ugly. Good condition.
I'll be pulling the control arms & spindles off of Ugly as well. Main reason, is so I can restore them, powder coated & all new bushings etc & put away. They will be ready when needed. It also lets me roll the car out of the shop for grinding, sand blasting etc. with the originals in place.
Removed the coil springs. 9 1/2" 2x4s put in to hold the front end up.
Cut what was needed out of the fire wall & trans tunnel for (another) V8 swap !
I have most of what I'll need for a 331 roller / stroker for this car. Including a set of NOS Headman Headers. I'll have those ceramic coated, inside & out.
I also have a WC T-5 O'll have re-built with strong parts.
I also picked up a 9" diff housing for this project. It will get narrowed , big axles etc. Likely be in the 4:11 range of gears. Will be OK on the street with a 5th gear.
The right door is junk (because I have others in good shape).
Going to "practice" splitting this door for a look see. Going to see what will be required to pull the crash bars out, to help lighten the car.
I have two sets of fiberglass fenders. One set very light - will go on this car.
I need one of them rotating devices too.. :(
dianne
Quote from: Reeves1 on July 30, 2015, 07:28:50 AM
I have a new rotisserie this car will be going on, in time. Will save me tons of time / work when the final sand blasting & sub frames are installed etc.
I have rotisserie envy now :(
Vehicles:
